TOPIC: M1sa vs. M1sb...?
M1sa vs. M1sb...? 11 years 1 month ago #772
  • Wowak
  • Wowak's Avatar
  • Thank you received: 8
And here I thought it was just to ease maintenance. In any case the front pumps are butt-ugly, so I'll be modeling the earlier configuration.
It does strike me as odd... when RDG put the drivers from the I10s that became T-1s under the I9sas, they called them I9scs... strange that there's not a class deliniation between M1sbs with two different driver sizes.
brianwowak.wordpress.com/
M1sa vs. M1sb...? 11 years 1 month ago #812
Per Edward Wiswesser in Steam Locomotives of the Reading and P&R Railroads, p 164, some M-1sb Mikados had their smaller drivers exchanged for 61 1/2 inch drivers "...for speedier wartime freight hauls and troop trains...". It goes on to say "Engines 1747 through 1756, among others, were so modified."
"Appendix 9, Complete Chronological Roster" shows a 1928 - 1829 rebuild of 1747 through 1756 to M-1sa standards, but does not say whether the driver size was changed then (though I suppose M-1sa means 61 1/2-inch drivers}. Each of the locomotives in that series did undergo rebuild during the 1940's when troop trains were running. If the drivers were not changed in 1928-29, they surely were changed during the 1942-1945 rebuilds.
George Nelson
Last Edit: 11 years 1 month ago by WindsorSpring.
M1sa vs. M1sb...? 11 years 1 month ago #816
  • Wowak
  • Wowak's Avatar
Very interesting. That throws a slight wrench in my plan to model the late 40s. I wonder if any didn't get the bigger drivers.
M1sa vs. M1sb...? 11 years 1 month ago #838
  • glenonoko
  • glenonoko's Avatar
  • Thank you received: 5
Bee Line issue #1&2 for the year 2000 covered Class M-1 in detail. From that magazine: #1700-1726 were originally built with the 61-1/2-inch drivers, while #1727-1756 originally had the 55-inch drivers. The smaller-drivered engines were bought for pusher and coal drag service, but they were mostly bumped from these assignments by the subsequent deliveries of Class N 2-8-8-2's and Class I-10 2-8-0's. This made the smaller drivered 1700's somewhat surplus, with many of them stored in the Depression. Thus 1747-1756 had the larger drivers installed in 1928, and 1727-1746 got the bigger drivers starting late 1941 through 1943. The last one converted was #1731 on 12/15/43.
Regards,
-- Rick Bates
The following user(s) said Thank You: Wowak
M1sa vs. M1sb...? 11 years 1 month ago #840
  • Wowak
  • Wowak's Avatar
So that settles it... a small-drivered M1sb would never have shared the rails with a T-1. Looks like I'll be invoking rule #1.
Time to create page: 0.121 seconds
