TOPIC: why is B8a wheelbase so short?
why is B8a wheelbase so short? 13 years 2 months ago #1191
  • gregc
  • gregc's Avatar
  • Thank you received: 1
I created an image comparing Reading loco wheelbases. While wheelbase lengthened with each new model in each class, the B8a is shorter than the B7a.
Was there some specific purpose this model was designed for?
greg
greg
why is B8a wheelbase so short? 13 years 2 months ago #1194
They were designed to work with the A4 and A5 0-4-0s on Philadelphia industrial trackage, Greg. They had to negotiate some very tight curves.
The following user(s) said Thank You: gregc
why is B8a wheelbase so short? 13 years 2 months ago #1210
  • gregc
  • gregc's Avatar
So why would they build 0-6-0s when 0-4-0s were available?
i see that the last A5s were built in 1913 (Wiswesser), B9s in 1918 and E5s in 1925. This suggests they needed bigger switch engines. Was this because the freight cars were getting bigger and/or the number of cars being switched increased?
Were the A5s becoming in inadequate for the size of the freight cars being switched in Philly?
I also see that they built 3 B8as in 1907, but built 7 B8bs in 1921, after the B9s.
This reinforces my belief that engines were designed with very specific purposes/routes in mind.
greg
Last Edit: 13 years 2 months ago by gregc.
why is B8a wheelbase so short? 12 years 6 months ago #2206
If I remember correctly it was because they needed more power in order to pull more cars for the Kensington industrial area as well as the Delaware Avenue industrial areas.
Time to create page: 0.132 seconds
