TOPIC: Reading new all green switcher and cab roof number
Reading new all green switcher and cab roof number 10 years 6 months ago #5253
  • RDG1519
  • RDG1519's Avatar
Hi Guy's,
I am re doing my Proto 2000 RDG switcher 1519 with a new Lok Sound Select Micro and Tony's Sugar Cube Mini speaker. It is also the time to repaint, restore a few items and also to add the cab roof number.
I remember a discussion, could have been on the MR forum, where in it was discussed that most if not all the Reading new all green paint schemes received cab roof numbers as well. For years I thought only the SW1001 and New Geeps had these.
Given this is the case, how are the numbers oriented? Like the SW1001 or???
Thanks for the help.
Chris
Chris
Reading new all green switcher and cab roof number 10 years 6 months ago #5254
Speaking off the cuff without my documentation handy, I'll say be careful with that. Not all the repaints got cab roof numbers and the ones that did not all have them oriented or facing the same way.
I don't know if the 1519 did or not. I will check my docs this evening if no one else jumps in here.
Last Edit: 10 years 6 months ago by Rob.
Reading new all green switcher and cab roof number 10 years 6 months ago #5255
  • RDG1519
  • RDG1519's Avatar
Gracias!
Chris
Reading new all green switcher and cab roof number 10 years 6 months ago #5256
Hey Chris...1519 definitely had roof numbers applied...the application was length wise down the center of the cab roof.
On page three of Robert Gottschall's book,The Reading Railroad Green Machines,there is a picture of 1519 and you could just make out the yellow numbers running down the center of the roof.Another example of this application can be found on page 348 of James Holton's book The Reading Railroad Vol.II.which shows the same application of the roof numbers down the center of the cab,although this was done on SW1200m 2711.It has been reported that this application was made to four repaints 1519,2711,614 and 449.The RS 3 is debatable but I've seen pictures confirming the other three units.The bottom of the numbers should face towards the engineer's side of the cab.
When I modeled my 614 I was in the same boat not knowing if it had roof numbers or not...I took a shot as to how they were applied and posted the following picture.
It turned out I missed the target...a fellow RDG enthusiast sent me a picture of 614 and I corrected the roof number application as shown below.
I don't remember his name and I no longer have the e-mail with the picture of 614 but he was sure 449 was done this way...So I modeled 449 the same.
Hope this helps.
Reading new all green switcher and cab roof number 10 years 6 months ago #5257
  • RDG1519
  • RDG1519's Avatar
Thanks Guy's.
Chris, it goes to show you that the minute we do something that needs additional research and we do it wrong, the correct information comes out, but only after we have done it wrong.
Luckily I knew this forum would have the information.
I will do my ALCO 449 with the same roof number so there will be at least two of them out here.
So far this little 1519 switcher has had three decoders starting with a DH123 15 years ago, a LokSound w/o notching from 6 years ago and now an upgrade to the LokSound Select Micro.
I will post pictures next week when I make more progress on this.
Thanks again, Chris
Chris
Reading new all green switcher and cab roof number 9 years 7 months ago #5823
  • RDG1519
  • RDG1519's Avatar
Well, as is usual things took a little longer than usual. I had a few extra details to revamp in addition to the roof number, and Lok Sound install. I am very pleased with it. While doing this I also did RDG 1501 since they are the same P2K model and well one thing led to another. I also finished my GP7 all green 614. Pictures of this another time.
Now the Towerman at Erie Avenue South Tower will see this one coming!
Chris
Time to create page: 0.145 seconds
