TOPIC: Reading Company kitbash corner
Reading Company kitbash corner 13 years 7 months ago #958
Looking good, Casey.
Reading Company kitbash corner 13 years 7 months ago #1007
  • VCtrainmaster
  • VCtrainmaster's Avatar
  • Thank you received: 12
so you scratch built everything but the frame and drive mech. basicly all the white plastic. is that right? and the tender?
If so thats great. I may even get a LNE buddy of mine to finally check out this site. He loves LNE camelbacks.
Great job! Casey.
Daniel J Mohr
Reading Company kitbash corner 13 years 7 months ago #1015
Yeah everything white and green, is scratch and it has the few parts I happened to have on it. The boiler is a piece of pvc I actually just found while helping clean up a family's homeI was going to use it to make my own boiler out of sheets of styrene but then realized it was the size I wanted already so just used it as is. If you consider the running gear as not used parts from something else I have like $30 in the project so far.
Also the repowered running gear is one of those brass gear boxes they made for a little bit with a motor stuck to the frame with something called VHB tape, a very strong foam tape I use at work a lot.
Reading Company kitbash corner 13 years 6 months ago #1117
Do the rivet decals come in radii patterns, or did you have to scab the front of the smokebox in sections? Looks really good.
Last Edit: 13 years 6 months ago by MrBill.
Reading Company kitbash corner 13 years 6 months ago #1124
They do on the sheet just not large enough for a smoke box front that was the most time consuming part, I did it 2 at a time. And even though its being painted and you won't really see decal imperfections I still hit the shells with gloss coat before I put them on just so they would stick better.
Heres what the sheet looks like,
Reading Company kitbash corner 13 years 6 months ago #1299
More Lehigh New England progress. I managed to be lucky and find a LNE O scale boxcar (I think) champion decal set for a tender logo. The cab doors will go on after some paint but paint will wait until headlight bulb is installed and I can add weight in the shell that is totally hollow right now, which I have yet to order.
and top plumbing view, mostly an educated guess only working from 2 pictures
