TOPIC: Lehigh Valley R-1 2-10-2
Lehigh Valley R-1 2-10-2 11 years 7 months ago #4257
Work started up again with installing the tender light which is the original tender light with the number boards shaved down. The light already has the LED in it and holes were drilled for the wires.
Then the water hatch was built made from a base layer of .040 and topped witha slightly larger piece of .010. Strips of .010 were used to make hinges and the lid split.
The front tender platform was then done to match the cab floor. Also the circuit board was placed back in.
Next I wanted to get a roof on the cab but first I needed to do the window frames and get a coat of paint in the interior. The frame and the arm rest is .010 plastic. I just do a simple coat of black for the cab interior since you tend not to see much of in there anyway.
The roof is made .010, so are the gutters and vents. Here is everything installed.
I put the original draw bar back in, I would like the tender to be a little closer but the generally tight curves won't allow it.
With the cab roof in place I made the slight coal bunker extension to not go higher then the roof line. The bunter extension was made from .040 pieces. The rounded front and back is something I noticed on pictures.
I then did the pilot footboards, they are made from .010 pieces. At this point the headlight was drilled for the LED that was in the original headlight.
This is where it sits now after a few other details were added. The bell, whistle, sand dome caps, generator and the base for the safety valves was made. A test run was also done, after some tweaking it's running well.
Lehigh Valley R-1 2-10-2 11 years 6 months ago #4287
With a visit to local hobby store I was a little surprisingly able to get the couple of detail parts I needed to finish this one. Before installing the parts I wanted to get the rivets done starting with the tender.
Rivets on the engine is just the smoke box, which is a little hard to see being a dark area.
The tender rivits were easier without a latter on the back so I build the latter after the decals were set.
Then the rest of the parts were installed ready for final detailing with plumbing. These include sander valves, air hoses, injector lifts, safety valves, pilot steps, washer plugs and main lubricators. The power reverse linkage will be built during final detailing.
Lehigh Valley R-1 2-10-2 11 years 6 months ago #4316
I doubt will get to work on the project more tomorrow so I figured I would update whats done. The tender, front and engineers side of the engines have the detail finished.
The tender was really just doing the various handrails.
The front was the boiler braces to the pilot and smokebox front hand rail. The eletrical line for the headlight came after the line along the boiler was set.
To do the power reverse linkage I wanted to get what was behind it on first which meant doing the sander lines then the injector pipes.
After the reverser linkage was in place the rest was applied.
Lehigh Valley R-1 2-10-2 11 years 6 months ago #4345
Over the week I finished up the detailing.
Then painting was done over the past 2 days. Decals are caboose for the tender type and the numbers are from a hodge podge of decal sets.
Still in the spray booth. I think the drivers look a bit smaller without the white walls.
On the diorama, at the time of the pictures the windows still needed to be done, but I wanted to do the video in the same day. They have been since applied.
It turned out to be a good quiet runner.
